Hi all,
I recently purchased a 93 250 4x with 66000 on it. When the brakes get warm or damp the rear brakes get a vibration and shudder noise in them. I pulled the drums, everything looks ok, pads look good, parking brake is fully released. Any body have and input on this?
The leading brake shoe should be slightly smaller than the trailing shoe, meaning there should be less friction material on it, the frame of the shoe will be the same size. If this checks out take the drums to be machined, they could be warped or bent.
