ho2s21 sensor code
Old Oct 18, 2007 | 11:40 AM
tommycattt's Avatar
tommycattt
ho2s21 sensor code
my truck, 1998 ford ranger 3.0 new moter new plugs new wires.
throws a code of misfire monitor fault along with ho2s21 sensor indicates lean
and ho2s21 sensor indicates rich I unplugged the map sensor and it quits the lean and rich codes but still misfires to the point of undriveable at intermitting times. some days never other days once other days the whole time i drive to work 14 miles.
I getting ready to clean the map sensor and was told by ford dealer use carb cleaner and be very carefull of the thin wire and never take it out when hot. any advice would be apreciated
Old Oct 18, 2007 | 06:18 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Welcome to the site!!!
Check out this forum here:
https://www.ford-trucks.com/forums/forum119/
For info on the 3.0l. Good luck
Old Oct 18, 2007 | 06:19 PM
Ultramagdan's Avatar
Ultramagdan
Welcome!
You will want to use the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and scroll over the boards. Lots of people have successfully cleaned their MAP and if you use a oil air filter (K&N, etc) you will need to clean it every now and then.
Old Oct 19, 2007 | 11:10 PM
tommycattt's Avatar
tommycattt
map sensor clean
I did remove and clean the map sensor here's hopein
JohnInBHM
New Member Introductions
Aug 12, 2007 12:50 PM
bigal66
Apr 3, 2007 09:11 PM
Richardwoods
Mar 8, 2007 05:05 PM
