Whining getting louder...
Old Oct 18, 2007 | 11:34 AM
71FoMoCo's Avatar
71FoMoCo
94 Ranger, 4.0L, 5sp, 194k mi.
Posting in both Ranger and Trans forums becasue not sure where this is coming from and will take all the help I can get!
Whining noise coming from drivetrain. Not motor - won't do it while free reving motor. Only does it when trans is in gear, any gear, and has to be engaged. Sounds similar to a blower spinning up and goes through every gear like that. Once at highway speed, it's constant. While changing gears, it dies down upon depressing the clutch, similar to a spinning down sound. It's like a "whir" or something. High pitched. Not sure what to make of it, but it's definitely a NEW sound to this truck - started about two weeks ago. Not at all familiar. Trans fluid maybe (manual)? Hoping someone has run into this before.
Mechanically, everything works as it should (for now at least). Runs really good. Strong, smooth. No clutch slipping or anything like that. Just this new noise. Got to be coming from somewhere.
Old Oct 18, 2007 | 03:24 PM
foxhopper's Avatar
foxhopper
I have this noise in my 93 5 speed. Interested in what others think. Seems like the older my truck gets, the louder I have to crank the radio to keep from worrying about all the new creaks and noises. ;0)
Old Oct 18, 2007 | 11:21 PM
blue beast's Avatar
blue beast
Have you changed the fluid out it should take atf not oil so it is pretty thin to begin with and too long of change interval, heat wear, water build up if not driven long enough and your getting pretty thin fluid on your bearings. I would change out the
fluid and add 3 to 5 oz of 30 weight oil and see if it stops the noise. It is probably the
tailshaft bearing especially if you tow or do alot of high speed driving both of which
require sooner change out schedule!!
Old Oct 19, 2007 | 03:56 PM
tomw's Avatar
tomw
Input shaft bearing. "Dies down when the clutch is depressed" The input shaft will stop rotating when you push in the clutch pedal. The tail shaft will be going at 'road' speed when in motion.
t
