Start-up fast idle
Old Oct 18, 2007 | 10:37 AM
loneleader's Avatar
loneleader
Start-up fast idle
'89 E-350 5.8L. Engine races for 1/2 second when started, then drops down to normal. Any Ideas?
Old Oct 19, 2007 | 04:00 PM
Gary B's Avatar
Gary B
elect.disconnect idle air control sol. start engine, base idle should be around 500rpm.adjust with throttle stop screw. reconnect, in that does not help remove IAC and clean the inside with carb spray,reinstall, disconnect battery for 5 min. if still no help there could be an EEC problem,mabye vacuum leak, or throttle position sensor. Auto Zone can get the codes out of it.
