Help!!
Old Oct 18, 2007 | 07:32 AM
deereboy89's Avatar
deereboy89
Help!!
I was driving to school one morning and as i went around a turn and started accelerating and the truck did a complete nosedive and killed on me then a few days later i was driving in town stoped at the stop light took off went about five feet and it killed again. That same day i was geting gas and after i was done i took off and it did the same thing. I was wondering if it was a sensor or something that was going bad but this problem is not obvious to me but maby some of u guys know it any help will be appreciated thanks.
Old Oct 18, 2007 | 10:19 AM
quicklook2's Avatar
quicklook2
the ignition actuator may be failing.
maybe bad fuel relay or loose connection.
Old Oct 18, 2007 | 04:37 PM
EPNCSU2006's Avatar
EPNCSU2006
It could even be a failing fuel pump. Try checking codes in the computer and see if anything obvious jumps out at you. Here's some instructions if you don't know how to get the codes already: http://www.thorssell.net/hbook/eectest.html .
Without some kind of troubleshooting, anything we suggest on the internet is just a stab in the dark (albeit maybe an educated, "been there before" stab in the dark).
