rough idle when cold
Old Oct 17, 2007 | 04:16 PM
beatfarmtruck's Avatar
beatfarmtruck
my F.I. 4.9 idles relly rough when i first start it up and fluxuates any where from 1500 down to 500 rpm until it finaly dies. it normaly runs ok once its warmed up but sometimes after i shut it off it does it again. i know most of the obvious parts have been changed. has anyone ever ran into this problem or have any ides.
Old Oct 17, 2007 | 05:47 PM
Ranger GT2's Avatar
Ranger GT2
What year truck is it? Is the check engine light on? Have you checked the fuel pressure?
Old Oct 17, 2007 | 08:07 PM
beatfarmtruck
it is a 89 and i dont think its fuel presser because as soon as it gets warmed up it seems to be fine but then again the reason im asking is cause i dont know. any easy way to check that?
Old Oct 17, 2007 | 08:09 PM
beatfarmtruck
oh and no the check engine light isnt on.
Old Oct 17, 2007 | 10:12 PM
blue beast's Avatar
blue beast
Clean the idle air bypass, use carb cleaner and hold the solenoid deal up so the cleaner
and gunk doesn't run into it an gunk it up. I would check the timing too.
Old Oct 20, 2007 | 08:34 PM
lv2race's Avatar
lv2race
Mine idles rough at first but catches up after a few seconds to a minute. Check for codes if your problem idle lasts longer then a minute.
