Sponsored by: Real Truck
oil change
Old Oct 17, 2007 | 01:17 PM
racerkeith1's Avatar
racerkeith1
oil change
I just got a 2006 f-250 with 6.0. I was wondering how much oil it holds, what is the recomending oil to run, and how often should it be changed?
Old Oct 17, 2007 | 01:42 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
6.0L Tech folder:
https://www.ford-trucks.com/forums/s...ad.php?t=303583
Everything you ever wanted to know about your 6.0.
Old Oct 17, 2007 | 02:44 PM
redford's Avatar
redford
FTE Leadership Emeritus
15W-40 is recommended for summers and trailer towing.
10W-30 is recommended for winter use.
5W-30 or 5W-40 is recommended for temps below 30F.
0W-30 is recommended for temps befow 0F
Change engine oil and filter every 5,000 miles when driving in severe conditions. Always change the filter.
Download an electronic copy of your owners manual and diesel supplement here.
http://www.motorcraftservice.com/vdi...&VEHICLE=F-250
Old Oct 17, 2007 | 03:30 PM
Tungsten's Avatar
Tungsten
Redford, that link doesn't work for some reason. I've seen it posted before and that was the same case then as well.
Old Oct 17, 2007 | 04:37 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Try Ford.com and search for it. Never mind, I found it. Go here:http://www.ford.com/owner-services/v...InfoButton.y=2
Old Oct 17, 2007 | 06:08 PM
Beerstalker's Avatar
Beerstalker
Motorcraft has their site set up screwy so it is hard to link directly to manuals. Here is a link to the site though.
Once there click on Owner Guides on the left side and then enter your year and make. It will then show all the guides available for your vehicle.
Old Oct 17, 2007 | 06:13 PM
redford's Avatar
redford
Dang....sorry about that.
Here's another link to try, but it won't have the diesel supplement:
http://www.analogstereo.com/ford_f250_owners_manual.htm
Bordermen
20
Sep 28, 2019 03:48 PM
Bvill01
21
Oct 9, 2012 06:41 AM
itsjustagreat1
Mar 5, 2009 08:24 AM
Adam0331
40
Aug 31, 2008 09:09 AM
bronco351
Apr 27, 2003 08:05 AM
