No 4x4?
Old Oct 17, 2007 | 08:23 AM
tron2003's Avatar
tron2003
Question No 4x4?
When I turn my switch for the AWD/4WDH/4WDL nothing happens, no lights on the dash, and the front axle doesn't engage. I checked my fuses and they all seem good to go. I also checked to see if the switch was getting power buy using a cuiruit light and it appears that the switch ISN'T getting power. I was wondering if there is a relay box I should be checking or if any others have had this stint and have any advise. Thanks again in advance.
Old Oct 17, 2007 | 11:10 AM
egmoss's Avatar
egmoss
I've had this happen several times. Try this quick and cheap fix. Disconnect positive battery cable, wait five minutes, re-connect battery cable. This will re-set the system and hopefully get you going.
Old Oct 19, 2007 | 07:51 AM
tron2003's Avatar
tron2003
THANKS!!!! 4x4 works like a champ now!
