rear diff problem 99 5.4 exp???????
Old Oct 17, 2007 | 12:03 AM
dr cabela's Avatar
dr cabela
started having grinding noises when i would turn rt or lt at slow speeds
got worse the hotter it was
sometimes the tires even squeal a little when turning
dont hear or feel anything when going straight
already changed the rear diff fluid
didnt help
i was told that it probably wasnt a wheel bearing but my rear diff needed to be rebuilt
the only kits i can find have to be purchased from the ford dealer......i think they called it a clutch kit and said it would have everything i needed ?
I HATE BUYING STUFF AT THE DEALER
any ideas??????
websites????
info??????
thanks
i have already fixed my odometer and a bad coil w/ help from this forum....it rocks!!!!!!!!!!!
Old Oct 17, 2007 | 10:10 AM
phil6608's Avatar
phil6608
If it's a limited slip dif the clutches do go bad.That may be the problem.
Did a google search and came up with this!
http://www.fordracingparts.com/parts...=Differentials
Old Oct 17, 2007 | 07:45 PM
AdamSmith's Avatar
AdamSmith
The dealer is referring to the clutch paks in the Ford Trac Loc differential. Usually a new set of clutch paks is $50 give or take a bit. The axles have to be moved out of the way to do it. If your gonna go that far I would do axle bearings too. A dealer will kill you in labor for this job.
Old Oct 17, 2007 | 08:18 PM
dr cabela's Avatar
dr cabela
lucky that i have as one of my pts a ford tech that is going to do it for $100
i just need to find if i can get the parts cheaper
or maybe he can get them cheaper
