Quick Question 57-60 Owners
Old Oct 16, 2007 | 01:26 AM
White_Knuckles's Avatar
White_Knuckles
My transmission has mounts on the bottom like there should be a crossmember holding the back of the transmission up. I can't find any bolt holes on my frame where a crossmember would bolt up and it looks like the transmission has just been supporting itself by the bellhousing for years. Should there be a crossmember there?
Also I need a lower bellhousing/flywheel cover for a 292, where could I get one?
Old Oct 16, 2007 | 05:46 AM
Walston's Avatar
Walston
no cross member on my 4 sp tranny
Old Oct 16, 2007 | 10:28 AM
Dan Tenn's Avatar
Dan Tenn
crossmember
No crossmember on my 60 223/3 speed
Old Oct 16, 2007 | 10:37 AM
56efffie's Avatar
56efffie
My 3spd overdrive tranny has the mounts too but nothing holding it. Must have been used in other applications I figure?
Old Oct 16, 2007 | 07:55 PM
White_Knuckles
Thanks guys.
Old Oct 16, 2007 | 09:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd assume that it is not the original trans if it has an actual mount in back.
Old Oct 17, 2007 | 01:24 AM
Col Flashman's Avatar
Col Flashman
Only Car transmission had them, not Truck trans.
Old Oct 17, 2007 | 09:51 AM
samahi72's Avatar
samahi72
No cross member in mine either. 223 4 speed. I will say that T-98 is one HEAVY transmission.
