2002 Explorer
Old Oct 15, 2007 | 06:06 PM
nascar_20's Avatar
nascar_20
2002 Explorer
Hi -
My daughter was riding with me today in the front passenger side of the explorer. She was resting one of her feet on a plastic oblong canister, one end has a connector on it, when it broke away from it's support housing. I am not sure if the the plastic support is broke but can someone tell me what it is and how expensive is it to replace?
Thanks, Tom
Old Oct 15, 2007 | 06:37 PM
rrgone's Avatar
rrgone
That's the vacuum reservoir for the climate control system. If it's broken or leaking you probably won't be able to switch between dash/panel/floor with the ac or heat, especially under acceleration. If it's not broken or leaking you can probably figure out a way to strap it up out of the way under the dash.
