'99 Ford Explorer
Old Oct 15, 2007 | 06:05 PM
R_Bartholomew's Avatar
R_Bartholomew
'99 Ford Explorer
Does anyone know where the feul filter is in a 99 explorer and how to get rid of valve pinging?
i have tried different grades of oil and gas to get rid of the pinging.
Old Oct 16, 2007 | 05:23 PM
1081's Avatar
1081
Under the driver's side of the car by the frame.
Old Oct 16, 2007 | 06:47 PM
97 Mountain Man's Avatar
97 Mountain Man
It could be carbon build up as far as the pinging goes. I recomend doing a Sea Foam treatment.
Old Oct 17, 2007 | 12:29 AM
CobraXP's Avatar
CobraXP
As 1081 said, it is on the driver's side on the inside of the frame. You have to use the removal tool (forget the specific name right now). You can get them from Pep Boys, etc, for about $10. They are the same ones you use on A/C lines.
97 MM has a good idea running SeaFoam through also. I would also do a regular tune-up at the same time.
Old Oct 17, 2007 | 07:12 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Dont forget when replacing the fuel filter to wear safety glasses to protect your eyes from dirt off the car and gas out of the filter and also do not forget to release the pressure of the fuel system before trying to r/r the filter.
