Sponsored by: Real Truck
5.4 engine swap
Old Oct 15, 2007 | 02:27 PM
STRANGE01's Avatar
STRANGE01
5.4 engine swap
Will a 5.4 from an 02 F-150 work in a 03-F250? What are some issues I will encounter while changing them out?
Old Oct 15, 2007 | 02:55 PM
redford's Avatar
redford
FTE Leadership Emeritus
It should work OK, just use the bolt on stuff from the Super Duty.
Old Oct 24, 2007 | 07:50 AM
STRANGE01's Avatar
STRANGE01
Has anyone ever pulled a gas engine from a Super-Duty? I have been told that I will need to remove the cab, or at least lift it several inches. Any tips or tricks?
Old Oct 24, 2007 | 07:53 AM
redford's Avatar
redford
Guys here have done it without lifting the cab, but I suspect they at least took off the hood, fenders (inner and outer), front grill, radiator (and other coolers) and the core support.
Old Oct 24, 2007 | 10:02 AM
JKBrad's Avatar
JKBrad
You will need to use the accessory drive items from your truck, swap oil pans and relocate the oil filter from the F150 location to the Super Duty location.
Old Jan 7, 2008 | 06:33 AM
STRANGE01's Avatar
STRANGE01
An update, if anyone cares.
Step 1, remove the radiator, fan, and shroud.
Step 2, remove the intake assembly, and all belt driven accessories.
Step 3, unbolt and remove the engine.
No body panels need to be removed, not even the grill or radiator support.
Old Jan 7, 2008 | 08:25 AM
redford's Avatar
redford
Did you get the engine swapped?
Old Jan 7, 2008 | 08:45 AM
STRANGE01's Avatar
STRANGE01
YES SIR! It took me several Saturdays to get everything done, but overall it wasn't that bad.
This past Saturday it took me and my dad 6 hours to install the engine, all the accessories, the intake, radiator, blah blah blah. We rolled the truck into the garage with no engine at 10:30 am, by 4:30pm we were driving it. Not bad for a couple of shade-tree mechanics, but we did have a lift.
Old Jan 7, 2008 | 08:51 AM
redford's Avatar
redford
Sweet! Good job.
Old Jan 7, 2008 | 06:19 PM
mrkevin's Avatar
mrkevin
mine was a v-10 and we swapped in a 5.4, now im wondering what it would take to swap in a 3v 5.4
907outdoorsman
1997 - 2003 F150
Mar 4, 2013 08:49 AM
sncblue03
Exhaust Systems
Feb 26, 2009 02:44 PM
Dieselguy89
1997 - 2003 F150
May 3, 2008 08:28 AM
somf
1997 - 2003 F150
Mar 9, 2005 12:51 AM
stover007
Modular V8 (4.6L, 5.4L)
May 16, 2003 10:29 AM
