Wow. Did ANY of you pass geometry? All of you whipped out the calculator way too soon.
Traderjoe came pretty close by identifying the right isosceles triangle. That was step one, but then he went to the calculator.
Since the hypotenuse (usually labelled 'c') is 27 units, each of the legs would be 27/sqrt(2). The area of a triangle is 0.5xbasexheight. In this case base and height are the same and are the two legs. So, if you multiply base times height, you get 27/sqrt(2) squared, which is 27 squared over 2. Multiply that by 1/2 to get the answer, so it's 27 squared over 4, which works out to exactly 729/4, or 182.25 units.
Your answer is EXACTLY 182.25.
Jason (who didn't even touch a calculator for this)
On edit: my apologies to buckarcher, who also had the correct answer, but didn't show how he got it (and also appeared to have whipped out the calculator pretty quick )
I used a pencil (not a pen) until I got curious how many digits the 19.09 went out to. But then I realized that it was limited by the places on the MS Windows calculator anyway. Oh well.
My point was that in geometry (and other mathematical disciplines in general) it is easier, quicker and more accurate to work through the problem with variables and radicals (like the square root of two) than to plug in numbers right away. Plugging in numbers makes you lose track of what you are doing--you lose reference to the problem you are trying to solve.
Ronwill's answer is a great example. He takes the square root of 364.5, coming up with 19.1, then turns right around and and squares 19.1 to come up with 364.8 (approximately), when 364.5 is exactly correct.
How's this for a different angle: any 'right' tirangle's area is half the area of a rectangle with the same two sides. I like Jason's answer best though, as the lengths of the legs are not provided. I just thought i would offer different perspective.
Traderjoe came pretty close by identifying the right isosceles triangle. That was step one, but then he went to the calculator. )
Calculator?? Nope! I whipped out my trusty, rusty, hemi-bamboo versalog sliderule. The batteries have never gone dead on that thing since I bought it almost 50 years ago.
