Looks like my radiator has multiple leaks. One is a crack along the top several inches long. Anyone know of a good place to look for a used replacement. I'm not ready to spend $300 on a new one right now. Engine is a 56 272 y-block. Thanks for any help.
The prices I got for repair or replacement of the core were about the same as buying a new one. The old radiators also have a much lower pressure rating. I opened some leaks in one of my radiators by putting on a higher psi cap.
You may just have a bad solder joint along the tank. I'd take it to a shop and have it looked at...sounds like you're on the right track seeking out a local shop.
Thanks for the replies. I guess I'll pull it and get an estimate. I'd rather try to get it fixed with the cost of these new radiators being so high.
Mike
A possible repair is always a good place to start as used radiators are hardly ever a good investment. You already have a used radiator, so why own two. Some shops charge more due to warranties or expectations of owner. Tell the shop keeper that you need only a leak fix and not a recore, maybe that no paper is needed and you will pay cash. These tips work at a lot of shops.
Are you still looking for a replacement radiator? I have one off of my '54 that i'm not using. The guy that owned it before me said it had just been rebuilt. Let me know.
STPJV:
Let me pull my radiator and get some quotes around town. If the repairs are too costly I will get back to you if you still have it then. Thanks for the offer,
Mike
