Hey guys, i was looking through ebay at the 351W EFI parts and i found this awesome looking intake. The only question is, what do use? A Throttle body or a carberator?
If you want more horsepower instead of excuses, consider theEFI SPYDER fuel injection intake manifold. Available forFord 302 (5.0L), 351W, 351C and 460 big block engines. The EFISPYDER manifolds accept any size throttle body (up to 90MM) andincludes jumbo fuel rails and "Power Elbow" plenum at no extra cost.
That looks awesome lol! Yea i knew that you needed to buy everything seperate. I was just stumped on what goes on there a carb or throttle body, i know now. Will a 302 Intake work on a 351w?
As previously mentioned, no, it will not work. The 302 manifold is narrower. Also, the intake you are looking into states "an ideal manifold for circle track or drag racing engines operating in the 3500 to 7500 rpm range." If you plan on using a carb on that intake, it will be crummy for wheeling.
mrknight01, that link you posted shows the 351W at $699,OUCH. Still no injectors, FPR or TB.
