hesitation help
Old Oct 14, 2007 | 12:08 AM
mooncricket's Avatar
mooncricket
hesitation help
i just got my motor back together last night got it runing good the only problem is that when i get on it it hesitates at first and then goes and goes good its just falls on its face on hard acceleration for the first sec
Old Oct 14, 2007 | 09:46 AM
havi's Avatar
havi
I'll have the Roast Duck
carb rebuilt, too? vac. advance?
Old Oct 14, 2007 | 01:00 PM
mooncricket
no the carb is new
Old Oct 14, 2007 | 01:11 PM
fmc400's Avatar
fmc400
MSEE
Maladjusted accelerator pump on the carb, low float height, dirty idle transfer slots in the carb, timing off, vacuum leak, vacuum advance not correct. One of those is most likely the culprit.
Old Oct 15, 2007 | 07:52 PM
mattimeo's Avatar
mattimeo
just fixed a similar problem. Turns out the power valve was to small and burnt out. It had a 6.5 instead of a 9.5 (check your inches of vacuum, divide in half and get the next smallest size).
