Im hoping some one knows somthing because I havnt found anything for a 97 460 as far as a tuner or chip. Mine is kinda doggy and I need to free up some power fast before I go insane with 8mpg and only 240hp and 350tourque
Is your truck OBD2? Some 97's are and some aren't. I bought a tuner for mine before checking and found out that mine isn't OBD2. So I have a tuner I dont need.
yah sry man, I wished i could tell you but im kind of a novice. Im not sure what that is and how I can tell but if you let me know I might have what ever that is and I might just have to buy it from you .
If your truck is OBD2 it will have a diagnostic port (plug in) under the dash towards the center hump closer to the drivers side. This is where you plug the tuner in to download a tune.
Ok I will go look after school, am I going to need to remove any of the dash or should I just find a plug in or not find one. And if you could take a picture or link somthing one where to find it better it would be much thanked. (sorry for the lack of knowlage on my part)
You dont have to remove or take anything apart. It should be very obvious. Look just under the lip of the dash. It should be black and about 2.5 inches long. There wont be anything connected to it.
im nearly positive the one that i found was a hyperchip or superchip, they wont say that they are specificly for the 460 and thats it, they work with alot of stuff you just need to get the right program.
