Sponsored by: Real Truck
need help on wiring
Old Oct 12, 2007 | 06:17 PM
Bustaduck's Avatar
Bustaduck
need help on wiring
I've got some new running boardes with lights need to know what wires to hook to so lights will come on and go off when door is opened and closed. color coded wires would be nice
Old Oct 15, 2007 | 09:27 AM
Beerstalker's Avatar
Beerstalker
Maybe the weekday crew can help you.
Old Oct 15, 2007 | 01:00 PM
Bustaduck's Avatar
Bustaduck
thanks maybe so went to dealer they wanted $50 bucks just for info. saved that 50 for fuel
Old Oct 15, 2007 | 06:07 PM
F250Gasser's Avatar
F250Gasser
Your best bet, although not the easiest is to try to tap into the interior lighting, try tracking it through the harness inside the front quarter panels, and Good luck.
Old Oct 15, 2007 | 07:01 PM
elmo8641's Avatar
elmo8641
on the back of your insterment cluster there are 3 conectors. 1 black, 1 gray, 1white. on the white conector, pin 2 a black and light blue wire. splice in to that. that is your interior light relay. that is what feeds all of your other interior lights.
Old Oct 16, 2007 | 08:36 AM
Bustaduck's Avatar
Bustaduck
thanks alot i'll jump on that as soon as i get off this 12 hour shift junk looks like monday if i have the energy thanks again
