Pump on / No fuel
Old Oct 12, 2007 | 02:16 PM
302RP's Avatar
302RP
Pump on / No fuel
OK, have a 91 f150 2wd. came with a I6 but have recently put in a 302 out of a 86 model, harness, PC the works. the original set up in the 91 had only one fuel pump (in-tank)I had to add the second high pressure pump. When I turn on the ignition the tank pump comes on for about 2 sec. and then shuts off. Which I believe is normal, right? Anyway I'm getting no fuel when it comes on. took line off before in-line filter and no fuel coming through the line. With the high pressure pump disconnected and only the tank pump kicking on I have air pressure building up in the rails but no fuel. Tank is about half full which I would think would enough to get the pump primed. Any thoughts or suggestions?
Old Oct 12, 2007 | 06:21 PM
quicklook2's Avatar
quicklook2
a 91 only has a high pressure pump in tank according to npd and lmc catalogs.
