Modular V10 (6.8l)
Backfire or pop!
Old Oct 11, 2007 | 08:09 PM
coaler97's Avatar
coaler97
Backfire or pop!
I have a 2002 f250 crew cab V10. Sometimes right after I start the engine I get a pop or thump that is heard through the passenger firewall. I had one guy tell me it was a coil. How can I tell?
Coaler.
Old Oct 11, 2007 | 09:41 PM
NoMo's Avatar
NoMo
Sounds like it might be the vacuum-operated blend door in the heat/AC system on the passenger side of the truck (behind the glovebox).
Vacuum leaks off overnight and the door opens up. When you start the truck and vacuum is re-applied, the door slams shut making a loud "thump" noise. Completely "normal" for that era of truck.
Old Oct 12, 2007 | 05:37 AM
Monsta's Avatar
Monsta
Sit. Stay.
Could also be a midget with a hammer that you wake up when you start the truck.
Try taking the hammer away.
NoMo, as usual, is spot-on.
Old Oct 12, 2007 | 10:08 AM
RAGaz's Avatar
RAGaz
HA!!!
Oh, I really needed a good laugh this morning, Monsta! Thanks man!
Old Oct 12, 2007 | 12:58 PM
coaler97's Avatar
coaler97
Thanks, I will look into that.
Old Oct 12, 2007 | 01:34 PM
Shasta69's Avatar
Shasta69
What he said.
Normal
