Steering Belt
Old Oct 11, 2007 | 12:43 PM
JDenver's Avatar
JDenver
Steering Belt
I know the steering upgrade is popular here but I have not seen a thread on this specific question. For those who have done the upgrade how did you set up your drive belt? I have the 2v water pump, alternator, and crank pulleys, I just flipped the inside one around to go around PS pulley, water pump and crank. Shortly after my water pump started to make noise. It is an old pump and I am replacing it now but I wondered if the stress from the PS pump may have accelerated its failure?
I ask becasue when I drop the PS belt the pump no longer made the noise.
I tried to go from crank only to PS pump but the clearance on my lower rad hose is pretty tight.
Thanks
Old Oct 11, 2007 | 05:04 PM
jowilker's Avatar
jowilker
JD, I just went out and looked at my truck. I have a double pulley on the pump/fan. Could be that if you don't the belt could have been out of aleignment.
John
