reverse light question?
Old Oct 10, 2007 | 08:15 PM
01redcrew's Avatar
01redcrew
i just put so extra reverse lights on my truck that i ordered for cabelas and i wired them straight to my orignal reverse lights. My problem is that my orignal lights arnt as bright now did i over loud the wire? Does anyone know what to do
thanks guys
Old Oct 10, 2007 | 08:24 PM
rbaker6336's Avatar
rbaker6336
could have,might need a relay in the system
Old Oct 10, 2007 | 08:50 PM
01redcrew's Avatar
01redcrew
have you tried this also?
Old Oct 10, 2007 | 08:52 PM
rbaker6336's Avatar
rbaker6336
no but when I run high amperage lights I always run a heavy battery wire to a relay
Old Oct 10, 2007 | 08:57 PM
01redcrew's Avatar
01redcrew
ok ill try and give that a try when i have time. thanks for the help
Old Oct 10, 2007 | 09:02 PM
rbaker6336's Avatar
rbaker6336
use the wire from reversse lights to activate relay
Old Oct 10, 2007 | 10:10 PM
stroken's Avatar
stroken
Yes, I added big rig LED lights to my truck and i wired it into the existing running lights and blinker..my stock running lights are not quiet as bright and my LED's are no were even close to being bright like they should,,,impossible to see at dusk when its a little dark out...not reverse lights but similar problem..i still havn't fixed mine..
Old Oct 11, 2007 | 01:38 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I ran a small set of 55w foglights on the hitch and wired them into the reverse light wire in the trailer plug, never a problem and it is a seperate fuse than the truck revserse lights so if you did blow a fuse the other lights would still work in reverse.
Old Oct 11, 2007 | 05:48 AM
just another truck's Avatar
just another truck
Drawing to much for the stock wires, thats why you have the dimming, to verify, use a DMM and check the voltage to the revearse lights. You will more then likely see between 10 and 11 volts. Like others have posted, I to tapped the the trailer wiring for my spare revearse lights.
Old Oct 11, 2007 | 05:24 PM
01redcrew's Avatar
01redcrew
what color is the reverse light trailer plug wire
Old Oct 11, 2007 | 05:30 PM
just another truck
Go to the "how do you know if you have towing option" thread posted today, someone put a print there.
Old Oct 11, 2007 | 05:59 PM
just another truck
Old Oct 11, 2007 | 06:07 PM
piotrsko's Avatar
piotrsko
If you have the tow package, the wire positions are either on the inside of the big round 9 pin trailer connector cover or the outside. I forgot which, and am too lazy to run outside to see.
Old Oct 11, 2007 | 06:09 PM
01redcrew's Avatar
01redcrew
you gave me that info that should help thanks
Old Oct 11, 2007 | 06:14 PM
rbaker6336's Avatar
rbaker6336
black with light green tracer
