391 Question.
Old Jul 29, 2001 | 03:52 PM
jicysa's Avatar
jicysa
391 Question.
What is the internal differance between a 391 and a 390. Just wanted to make sure distributors would interchange. I want to convert '73 391 to electronic ignition from '76 390.
Thanks for any info.
Jicysa
Old Jul 29, 2001 | 04:13 PM
460v10's Avatar
460v10
391 Question.
Jicysa
I believe the 361 and 391 truck engines use an oil pump with a 5/16 hex, instead of the common 1/4 hex, like the FE series. If I remember correctly the gears are the same, but the pilot in the block is larger.
Old Jul 29, 2001 | 04:24 PM
jicysa's Avatar
jicysa
391 Question.
Thanks. I will probably look at the Pertonix Ignitor for simplicity
Old Jul 30, 2001 | 12:33 PM
proud owner's Avatar
proud owner
391 Question.
