Sponsored by: Real Truck
ABS light
Old Oct 10, 2007 | 02:45 PM
earl964's Avatar
earl964
ABS light
The VSS on top of the pumpkin. Is this the wire going into the top of the rear differencial How can you check it to see if it is bad I took mine out and cleaned it and after about 1 minute the ABS light came back on before it would come on as soon as you started the truck
Old Oct 10, 2007 | 03:04 PM
BillyBob69's Avatar
BillyBob69
Just replace it. It is only about $15.00. I tried the cleaning mine as well..no luck. But when you go to get the replacement....make you you specify the ABS speed sendor. If you just go for the VSS, then they will look up the one that goes in the tranny.
Old Oct 10, 2007 | 04:40 PM
Big Orn's Avatar
Big Orn
Could also be the sensor on the front axle - this is for the 4wd truck...right?
Old Oct 10, 2007 | 04:44 PM
earl964's Avatar
earl964
yes it is a four wheel drive should I replace them both?
Old Oct 10, 2007 | 04:47 PM
Beerstalker's Avatar
Beerstalker
Is the speedo acting up? If so replace the rear one.
Old Oct 10, 2007 | 05:39 PM
earl964's Avatar
earl964
The speedo is fine
Old Oct 10, 2007 | 06:56 PM
dougc's Avatar
dougc
Try checking the tire pressure also. This is either a really good suggestion or my truck is mental! I had a slow leak in one of the front tires and the ABS light would always trigger when the difference in air pressure between the front tires was 5 psi or more. If works for you, great; if not two VSS are only $30.
