Last 352 made?
Old Aug 14, 2001 | 09:23 PM
greg ne's Avatar
greg ne
Last 352 made?
This has probably been asked many times before but when was the last 352 put in a truck? I have a friend with a 68 F250 that he rolled and I am interested in buying the motor out of it. We think it has a 390 in it as he bought it from the orginal owner and thought it was a 390 but it has an air cleaner that says 352 on it. The truck has only around 80,000 miles on it and was a camper special. Thanks in advance Greg NE
Old Aug 14, 2001 | 10:21 PM
jowilker's Avatar
jowilker
Last 352 made?
Greg, find a piece of 14-2 house wire about 10" long, and pull the white wire out of the jacket. Remove one of the front spark plugs and stick the wire in the hole. PLace a pencil on the white jacket and have someone turn the engine over with a wrench on the crankshaft bolt. Measure the mark from top to bottom. 3.5" = 352, 3 3/4" = 390 The truck could have a 360 in it as well 390 block with a 352 crank.
Have fun guessing and let us know what you find. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Aug 15, 2001 | 09:59 AM
ksd's Avatar
ksd
Last 352 made?
1967 was the last year for the 352, as the 360 was introduced in 1968. The only difference is the 352 has a 4.00" bore, whereas the 360 has the 4.05" bore also found in the 390. Both the 352 and 360 have a 3.50" stroke. If you measure a 3.50" stroke, you can check the casting numbers to see if it is a 68 or later block. If so, you've almost certainly got a 360. If the stroke is 3.78", you've got a 390.
ksd
69 F100 Explorer lwb 2wd FE 360 C6. WANTED: straight/clean styleside long box w/aux fuel tank for 67-69 F series.
Old Aug 15, 2001 | 08:57 PM
greg ne's Avatar
greg ne
Last 352 made?
Thanks for the info. I guess I have some detective work ahead of me. Greg NE
Old Aug 16, 2001 | 12:37 PM
fairlaniac's Avatar
fairlaniac
Last 352 made?
