Sponsored by: Kumho
Emerg brake cable...
Old Oct 9, 2007 | 03:17 PM
tripod's Avatar
tripod
Question Emerg brake cable...
99.5 SD,250,7.3,6 spd.The stop on the cockpit end of the cable came off and cable feathered.Will I just buy a forward cable section or will I have to buy rears also? Is there a step by step anywhere on this site.Thanx.
Old Oct 10, 2007 | 06:44 AM
ubereal2's Avatar
ubereal2
I'm pretty sure those cables are in sections.
Old Oct 10, 2007 | 02:43 PM
rebocardo's Avatar
rebocardo
Not having a 99.5 SD in front of me, all I can say is almost every Ford (RWD - drum brakes) I worked on had a front cable, then it went to an adjuster and off the adjuster comes the rear cable.
Easy enough to search on Advance Auto to find them.
Old Oct 11, 2007 | 07:32 AM
tripod's Avatar
tripod
Angry
I may have got hosed.I nursed my truck to a local mechanic to R/R a broken brake line at the frame (left) and as a good mechanic looking for a buck,he said my rear shoes were worn completely down and needed changing,I said ok.He showed me a pair of worn disc brakes so I would know how bad they were.I always thought the rears on a 99.5 were drums.so,did he put it to me?
Old Oct 12, 2007 | 12:43 AM
ynevada's Avatar
ynevada
u dont know if u have drum or disc? look through the wheel, u can see which it is.
if its shiny, its disc. dull, dirty, rusty, its drum.
but most had disc.
but did he say ur shoes were worn, or ur rea brakes were worn?
Old Oct 12, 2007 | 03:42 AM
bradshaw6243's Avatar
bradshaw6243
Old, but not too old
If you have drum brakes and he showed you worn discs, you have indeed been had. I hope that is not the case.
Old Oct 12, 2007 | 02:02 PM
tripod's Avatar
tripod
Red face
After getting off my **** and visually checking the brakes,they are disc's.I thought I'd been had when previous message said all RWD had drums.Thanx for your input.
Old Oct 12, 2007 | 04:34 PM
rebocardo's Avatar
rebocardo
That is not what I typed, just how you read it. I was telling you the type that usually had the cable setup I described was -> (RWD- drum brakes).
So ... did you go to Advance and get a new front cable?
If you need instructions you will find the Haynes manual the better of what is cheap and they sell it at Advance.
Old Oct 13, 2007 | 07:06 AM
tripod's Avatar
tripod
Red face
Like my 5th grade teacher said,"there is a difference between looking at words and reading words".On my way to AA now.
