Need Socket for 4wd front axle
Old 10-09-2007, 12:00 PM
ealbertson's Avatar
ealbertson
ealbertson is offline
I need the socket for the nut that holds the front caliper on. I have a 97 pwd 4 wheel drive crew cab. I am not sure what type axle it has. If you can tell me how to figure that out I can probably find the right socket.
Any help will be greatly appreciated,
Thanks, Ed
Old 10-09-2007, 12:06 PM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
IIRC it is a big metric. 14-18 MM. Can't remember. If it is a independent suspension it is a D50, which is most likely on the 250. 350's have the D60 I believe.
Old 10-11-2007, 07:48 PM
97 RED PSD's Avatar
97 RED PSD
97 RED PSD is offline
It takes a 21 MM socket for the caliper mounting bolts for a Dana 50 which is on the 250s. For a D60 on the 350s I'm not quite sure, but guessing it would be the same.
