I need some help here... my TTB just went kaboom, and if someone has done it i need instruction on how to dis-assembly the TTB, what should i look for?. Any diagrams would be very helpful of course .
What Broke That You Need To Replace? Going To Put A Straight Axle? I Put A Straight Axle On Buddies 95 F-150, So I Took The Old Out. Let Me Know What Your Doing.
Well... it was actually easier than i thought, only some pin gave trouble, now checking the inside it seems the gears and the like are just ok (i was expecting a true mess, as the truck sounded and felt real bad when i moved it), only the bearings show damage, so i´ll replace them all (i got some Federal Mogul and Timken spares today).
I might consider the swap later, but this TTB has worked pretty well so far.
