colder A/C??
From that we can tell if the refrigeration portion of the system is working or not. If it is, then we can move on to the air handling portion of the system including the heater valve and fresh air flap.
high side was right at 200. Low side is at 40. Temp originally after charging and half way thru the next day at the vent was 41 degrees. The next afternoon though....60 was the stopping point. after several days of driving around with the A/C on...my brother came over yesterday and we checked it all out again. 58 -62 at the vent temp, and same pressures....the compressor had condensation all over it, the low side line is all nice and cold and frost on the fittings...the high side line is all nice and warm going to the codensor...
any other info needed?
I'm not looking to create the frozen tundra in my truck...however I do want A/C that works and cools the cab down to the point that the A/C is a better option than driving faster with the window down.
If i knew that the system was fully functional with no issues and that the $90 worth of freon would be the last $90 I'd have to spend on the A/C...then I might consider that....but that hasn't been the case to this point.
however, after getting it to cool down to 41 degrees for a day I don't think the freeze 12 is the issue here. and if I can get it back to 41 degrees...then I'm happy without blowing $90 on R12.
The way I charge mine is by setting up a blower to cool the engine. Then I set the idle at 1200 rpm. This will give you the pressure drop like going down the road. With R-12 I shoot for a low pressure of 32-35 psi with the fan blower on HIGH/MAX Cooling. If every thing is working right this should give you around 32 - 35F discharge temp. You high side should be around 200. With an expansion valve system, the sensing bulb controls the amount of coolant that goes through the valve. And it will keep the evap from freezing up. The key to ultra low temp is to run as close to 32F vapor temp as you can on max high speed colling. Now as the cab cools down you will more that likely lower the fan speed. This is turn will drop the air tem some more, the TXV will keep it from freezing up. Most TXV systems have a site glass to aid in charging. Normally found on the drier or the liquid line running to the cond. If charged properly you should see liquid and not bubbles under stable condition. While it is handling high heat load seeing bubbles is expected. Infact you should be able to see the txv opening and closing at the site glass and on the low pressure gage.
I do not waste freon. I always pressure test with nitrogen gas. This has a smaller molecure than Ref and will leak easier. If I get a leak I go hunting, using soap and my ultrasonic leak detector. NO ref is added if a leak is present. This may take several times to find all of the leaks. I would not use CO2, this forms with water vapor and creates acid, NOT Good.
My dealing with Freeze 12, Don't waste your money.
orich
when I look thru the sight glass, it looks like fluid...no bubbles.
orich..not sure what you mean with a liquid or a gas... we use the standard pressurized can of freon (in this case freeze 12)...puncturing the bottom of the can with the gauges and run the liquid into the system.
we put the gauges back on over two days later and the pressures were the same...just not getting the vent temps like I had. we did have a small leak on the high side valve to the compressor when closing it - i ordered one and finally have it...will put it on tomorrow evening. so I know its leaking some there...however...if the pressures are still the same, is this small leak enough to raise the temp 20 degrees?
we replaced the condensor because it was leaking in several places. after dismantling the whole system and flushing everything with endentured alcohol, we put it all back together...new orings all the way around. any hoses that were not crimped were double clamped. pulled the vaccum to 30 and it held for over an hour....then we went to charging.
blue thanks for the advice with Nitrogen gas...and what about Freeze 12 did you have issues with?
we'll put on the new high side valve to the compressor tomorrow night and I'll check for leaks around it all...and see where we go from here.
thanks for the info again.
After clean the system did you add the oil back into the system componets? Dryer 2 oz, cond 2-4oz...... I have a book that gives most of these values. These are just examples I did not look actual values up.
I always charge by pressures. I do not rely on what any tag may say. If any componet was changed the tag could be wrong. Particurilly if hoses were changed. Then the size of the r12 cans changed over the years. Started out as 16oz then 14oz, and 12oz. So # of cans may are not a good reference.
Are you seeing any indication of the Expansion Valve controlling? Like 2-3 lbs change in the low pressure change. I have seen brand new valves be stuck and not work. Did you wrap the cotton (black sticky tar) tape around the valve. Is the sensing bulb clean and tight on the suction line?
Things to do, while you are trouble shooting. Block off or bypass the water to the heater... These only have to leak a very little to run the discharge temps up. 180F beats 32F any time.
Your 40-200psi at 85F are pretty close to normal. 40 is high for the low side, I prefer the lower 32-35psi. A leaking HW control valve can easly boost the pressure to 40 and greater. If you have access to the TXV (sensing bulb) while in use, use a heat gun and watch your pressure. The low should raise and hi drop as the valve opens up.
Good luck
When charging keep the los side below 50 pis and the high side below 240. You can add freon gas with eng. off and when it stop going in close valve on manifold ga. When start eng run rpm to about 1200 when putting in Gas. Well got to go for now..
good luck...my 2cents.
orich
blue...thanks for the info on Freeze 12 vs. R12...I actually did some more "discussion" with another mechanice who I respect very much....he also says that the Freeze 12 doesn't cool as good as R12 and can be a little "finicky". We did add oil back to the compressor about 5 ounces. and we added between 5 and 6 to the line going into the dryer and condensor. we had such a hard time with the fit of the condensor and dryer that we didn't think about putting oil in it while it was easy to access...so we used the hose from the compressor to the dryer (and then condensor) and put the oil in thru the hose. (by far not the best choice or the cleanest application...but one that should have accomplished the goal.) we were told between 10 -12 ounces total for the system with 5 being in the compressor and the remaining in the dryer and condesor.
I don't have any prior experience with A/C work although my brother does and is helping me with this (they're his gauges, etc). I can comment on the TXV whether or not it is working...but will get him to read this and tell me. the black sticky tar tape that was on the TXV when we replaced it was hard to get back around it. we put it back around it best we could and then took some of the foam pipe insulation that is cut down one side...we cut a piece about 4 inches...and put it over the TXV and the remaining black tape and taped it up with electric tape. we'll check he HW control valve for leaks and block it off to see if that changes anything.
orich...in your post, you mentioned this being for a 73...but mine is a 76 - would they be the same? and I thought you always wanted to add the liquid and not the gas to charge a system?? you're saying it's opposite of that - add the gas and not the liquid??
thanks again to both of you...hopefully we can get it working like it's supposed to! I'll post back with any updates.
david
