e4od box location?
Old Oct 8, 2007 | 09:19 PM
larry1211's Avatar
larry1211
e4od box location?
Can anyone tell me if there is a control box to control the tranny on the inside of the cab on a 1992 f150 e40d and if so what does it look like and where is it located??
Old Oct 8, 2007 | 09:58 PM
jk89cat's Avatar
jk89cat
its in the pcm
Old Oct 8, 2007 | 10:08 PM
Skandocious's Avatar
Skandocious
Maybe this will help...
E4OD Automatic Transmission Electronic Control System Component Locator
Old Oct 8, 2007 | 10:24 PM
larry1211's Avatar
larry1211
there is a box behind the kick panel on the passenger side that has a red light blinking.....do you know what this is??
Old Oct 8, 2007 | 10:42 PM
Skandocious
I believe the control box behind the passenger kick is for the electronic 4x4 shift system. Do you have electronic 4x4?
Old Oct 8, 2007 | 10:48 PM
larry1211's Avatar
larry1211
e4od box location
yes it is 4x4......i pushed a button on it(the box) and the little red light started flashing and i couldnt get it to go off......
Old Oct 8, 2007 | 10:51 PM
Skandocious
I'm not aware of a box with a red flashing light behind the passenger kick panel... Maybe someone else can comment here...
Old Oct 9, 2007 | 08:26 AM
Conanski's Avatar
Conanski
Is it the item identified in this post as the fuel inertia switch... https://www.ford-trucks.com/forums/6...help-guys.html
Have a look at the picture in the 8th post down..
Old Oct 16, 2007 | 01:55 PM
larry1211's Avatar
larry1211
the box is in fact the 4x4 control.......thank you
Old Oct 16, 2007 | 01:59 PM
Skandocious
Woo! 1 point for Chris Glad you got it all worked out buddy.
