How to Pull Steering Wheel
Old Oct 8, 2007 | 05:35 PM
Grimper's Avatar
Grimper
Hi,
I've got a 1996 F-150 XLT 4x4 with a worn-out turn signal switch. I've never pulled a steering wheel that has an air bag, so I could use some sage advice.
I gather the battery has to be disconnected for a few minutes before I do anything. I've got a variety of steering wheel and gear-pulling devices. Do I need any special tools? (The truck's got a tilt wheel.)
Thanks in advance for detailed instrux!
~Grimper
Old Oct 8, 2007 | 05:54 PM
17fordguy's Avatar
17fordguy
no its simple for nuts back side of sterring whell un hook plug for air bag unbolt and pull
Old Oct 8, 2007 | 06:13 PM
flareside_thunder's Avatar
flareside_thunder
Unhooking the battery wouldn't do any good probably anyways...alot of airbags come with a backup power storage in case a battery explodes during a wreck.....
Old Oct 8, 2007 | 08:12 PM
Grimper's Avatar
Grimper
Thanks. So do I have to do anything special to ensure that I don't accidentally set off the air bag while taking apart the steering wheel?
Old Oct 8, 2007 | 08:15 PM
flipklos's Avatar
flipklos
1-Pull from the pop on the air bag unit monted on the steering wheel.
2- disconect terminals.
3-cover open leads W tape.
4-Have fun! that steering colum is a pain.
Old Oct 9, 2007 | 09:24 AM
Grimper's Avatar
Grimper
I found this helpful instuction page while looking for a replacement part:
http://www.dzljim.com/Ford/mfswitch.htm
~Grimper
Old Oct 9, 2007 | 08:26 PM
cjg1999's Avatar
cjg1999
~Grimper
you dont need to pull the wheel to replace the turn signal switch, i did it a few months ago witout taking the wheel off. Its 2 scrwes under the column trim.
Old Oct 9, 2007 | 08:42 PM
Grimper's Avatar
Grimper
The guy who wrote the web page that I cited above also said that he thought it was possible to leave the steering wheel on. I'll try that first. Thanks.
Old Oct 9, 2007 | 09:10 PM
subford's Avatar
subford
WARNING:
THE ELECTRICAL CIRCUIT NECESSARY FOR SYSTEM DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY AND BACKUP POWER SUPPLY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE BATTERY POSITIVE CABLE MUST BE DISCONNECTED FOR ONE MINUTE PRIOR TO SERVICING OR REPLACING ANY SYSTEM COMPONENTS.
1. Disconnect battery positive cable and wait one minute for backup power supply energy to be depleted.
Old Oct 9, 2007 | 10:43 PM
91 F-150 Farm Truck's Avatar
91 F-150 Farm Truck
Oh yeah and don't let the posi touch the body
