1975 E350
Old Oct 8, 2007 | 02:17 PM
davidsquires's Avatar
davidsquires
1975 E350
sorry about posting in wrong heading. But I will try again --1975 E350 van chassis w/ motor home 351 cid not sure if it is a w or c ( the intake does not have a valley pan type gasket) small bolt pattern c6 auto trans. My question is what is base timing and does the distributor require manifold vacuum or secondary throttle vacuum. I know this unit is heavy -- but it feels like the engine is bogged down and not making the rpms. passing gear seems fine as i can hear the engine taching up.
thanks David
Old Oct 11, 2007 | 03:09 PM
spikedog's Avatar
spikedog
Base timing should be 12 degrees BTC. You might have a 351M rather than w or c. Hopefully there is a sticker somewhere under the hood with all that info.
Try a search on the older truck forums on the vacuum source question - it comes up fairly regularly.
Old Oct 11, 2007 | 03:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
thanks David
It's a 351W (6 valve cover bolts).
No 351C's (8 valve cover bolts) were used on F Series trucks, Econolines or Bronco's...ever.
Old Oct 16, 2007 | 03:42 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
thanks David
Motorhomes really need a custom advance curve so that you can run a decent amount of base timing without experiencing detonation.
Try direct vacuum first, because this will give you extra vacuum advance at idle, keeping your spark plugs cleaner over time; however, some motors tend to idle too rough or too fast hooked up direct, in which case, you should run ported vacuum.
http://www.PerformanceDistributors.com
info@performancedistributors.com
</O
<O
__________________
FTE Sponsor
Performance Distributors
