Engine assembly
Old Oct 8, 2007 | 09:03 AM
mrwolf's Avatar
mrwolf
Engine assembly
Can anyone recommend a good book that would tell me everything I need to know on how to assemble a 1993 7.3 diesel engine.
I have an engine all apart in a box and I can't see it being that difficult of a job to put it all together but would like to know things like clearance and how much torque when assembling bolts
Looks like a good winter project for me
even an email address of somewhere I can ask a question or two would be great
Thanks
Old Oct 8, 2007 | 10:07 AM
PLC7.3's Avatar
PLC7.3
I will help you as much as possible with some of the info you need....... PM me you email addy.......... which part of BC are you in....
Old Oct 8, 2007 | 03:44 PM
catfish101's Avatar
catfish101
Other then the heads and main bearing caps and rods caps everything else will be standard bolt torque which a chart can be picked on-line.
Old Oct 8, 2007 | 10:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Haynes Diesel Engine Repair Manual will have some tips, tricks and specs.
Available at most auto part stores the book number is #10330.
Cost is about 20 dollars if I remember right.
Helms has a much better book, if you can find one.
It also has a much higher price, usually around 100 dollars.
Jesser02EX
22
Oct 18, 2015 08:10 PM
newr
1983 - 2012 Ranger & B-Series
Aug 4, 2014 02:25 PM
goatsniffer
13
Nov 7, 2008 07:23 AM
earl964
Oct 29, 2007 03:12 PM
Frenchy
Sep 29, 2005 10:16 AM
