Old Jul 31, 2001 | 09:16 AM
buzzard's Avatar
buzzard
360/390
Old Sep 21, 2001 | 03:18 PM
onebad40willys's Avatar
onebad40willys
I was looking at destoking a 360/390 with the 330's crank and 390 rod's and running a high lift cam. Any suggestions on a build up for a 4x4 also tought of stroking it with a 428 crank to a 410. Also is there any difference in the 360/390 2v heads verses the 390's 4v head's in the truck's. thankx for any and all suggestions.
Old Sep 21, 2001 | 06:34 PM
FE427TP's Avatar
FE427TP
360/390
nope, same castings most likely C8AE-H or D2TE-AA
Old Sep 23, 2001 | 02:29 AM
karljay's Avatar
karljay
360/390
Destroking is good for light weight, high revving but not good for most 4x4's. Rather than destroke an FE for high RPM use, I get a 351W small block, it's cheaper and can rev higher.
The 390 is a great truck engine and the 410/428 crank is even better but the FE in this form is usually best <6000 rpm. The torque output of a 428 crank in a 390 block is unreal.
