LED lite question
There are two different styles:
2-pin - Requires that you reverse polarity of the drive voltage to change color
3-pin - Has two separate inputs and one common pin. Drive voltage is applied alternately to the inputs to change the color.
Steve
Get some tri color and you'll be able to see right where the switch is at night!!
555 timers rock!! Go to radio shack ask for their real catalog, they don't like to hand them out I guess they don't want to order stuff. It has a lot of IC chips in it, the web site doesn't have squat compared to the real catalog. You could use regular relays to do the same thing. But get a breadboard and the IC and wire it up on the BB and then you could either just use a blank board and solder jumpers or you could get the PCB kit from radio shack, It is easier than you think to make a circuit board. Trace out your circuit paths with a sharpie, dunk in the etchant, drill holes for circuits, make sure to drill an extra hole where the wire attaches run the wire thru the hole tie a knot in it and then solder to take the strain off the joint. I use empty AA and D battery packages as project boxes if you can't see the thing, or you could go the pretty project box route!!
When your "arm" switch goes hot, the NC side of the activation switch will be hot, lighting the green LED. When you hit WOT and the activation switch goes from NC to the NO terminal, the green LED goes out and red comes on. If your activation switch only has one terminal, then use it to drive a relay with a NC and NO terminal and run the LED the same way off the relay.
Sounds a bit complicated to say, I can post a simple schematic later, but cant get a picture through the firewall at work.
OK if you want to add the red / green LED and your "activate" microswitch has a normally open and normally closed terminals: (crappy freehand sketch, but you get the idea)
http://i178.photobucket.com/albums/w...doublepole.jpg
If your microswitch only has one pole, add a simple relay:
http://i178.photobucket.com/albums/w...singlepole.jpg
A couple of PS's:
If your LED has a standard ~2.2V forward voltage and 20mA current, you would need about a 600 ohm resistor to make it compatible with the trucks 14V electrical system.
Also, you want the "common cathode" variety of LED for this set-up as you will be using two + inputs and a common - ground.
