360 cam question
second question. I have never changed a cam, how difficult is it to do? If I remove the radiator and grill can I do it with out removing the engine.
Thanks is advance
The cam change is not that hard but you will have to pull the front off the engine (water pump and timing gear cover and any acessories) plus remove the radiator to get enough room for the cam to clear the engine and remove the intake manifold to change the lifters. You should also change the valve springs which can be done without removing the heads but you have to be careful.
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
