General Automotive Discussion
2005 marnier overdrive problem
Old Oct 7, 2007 | 09:12 PM
veldog's Avatar
veldog
sometimes my 2005 marnier will not shift into overdrive. at 65 mph the tach reads around 3000 rpm, it usually reads around 2000 rpm when in overdrive. the o/d off indicator is not lit. when you disengage the o/d on the floor shift the indicator lights. there is no change in rpm either way. if you floor the gas pedel into passing gear then release the pedel it will then go into overdrive and work correctly. this happens once in a while. trans has 24000 miles and fluid level is ok.
