Sponsored by: Auxito
Cargo Liner for 2003 Supercrew
Old Oct 7, 2007 | 02:09 PM
rapidag's Avatar
rapidag
Does anyone know where I can purchase a liner that will cover the back seats once they are folded down in my 2003 F150 Supercrew?
Looked around but all I find are floor mats. New dog will probably destroy that light carpet that backs the seats.
Any help is appreciated.
Thanks,
Mike
Old Oct 7, 2007 | 09:24 PM
Aftrmidnite's Avatar
Aftrmidnite
I went to Lowes and bought some indoor/outdoor carpeting. I bought double the amount I needed, cut it in half and sprayed the backs with contact adhesive. Using three people I glued them evenly together, you only get one shot at this!! I cut a square out of the corners, then sewed together to make a box, with a sewing awl and upholstery needle. You push the awl thru, and slightly pull it back, there will be a small loop, push the threaded upholstery needle thru the loop, pull the awl back thru the carpet to form a lock stitch. It goes faster with two people. If I had of thought about it I could of made the carpet box using just the carpet. Just don't put adhesive on the corners and you can make the carpet box using glue lap joints. Use Velcro for the end nearest the passenger door, so your dog can get in and out. Ps you maybe able to find an upholster to sew the carpet. I put instrument cases in mine. Also they have seatbelt/harnesses for dogs.
03f150screw
New Member Introductions
May 24, 2007 11:13 AM
SuperCrew4U
2004 - 2008 F150
May 15, 2006 07:28 AM
RSTX
1997 - 2003 F150
Jun 8, 2005 08:19 PM
spamsoilman
Aftermarket Products
May 16, 2003 07:28 AM
