Power Window Buttons Lights
Old Oct 7, 2007 | 11:19 AM
angelo's Avatar
angelo
Hi,
On my 2000 xlt drivers door the illumination went out on all the window buttons, door lock button and remote mirror switch. I think that's 11 LED bulbs all together.
It's not a fuse or dimmer switch.
The passenger side window and door lock buttons are lit and all the windows work, the remote mirrors work and door locks work from either door.
It's just that the buttons are not lit on the drivers door.
I had the panel off the drivers door and I did take the switch apart.
they are LED and soldered into the board.
Which of all those wires deal with illumination and how do you check them??
Find it hard to believe that all these bulbs went at the same time only on that door, and I think that the only connection between the windows, door locks and remote mirrors is the fact that all the buttons get lit at the same time.
Also noticed that the headlight switch is not lit up, but I don't know if thats been that way for a while or not.
Any ideas?
Thanks, Angelo<!-- / message -->
Old Oct 8, 2007 | 07:38 AM
mason's Avatar
mason
Headlight switch light going out is pretty common. There is a bulb that can be replaced. I have the part number at home but I' m at work now. A good parts man should be able to find the number for you. It shouldn't cost much. Haven't heard of the P/W switch lights going out before.
Mason
Old Oct 8, 2007 | 11:35 AM
angelo's Avatar
angelo
Thanks, mason
Glad that at least that bulb can be replaced!
Angelo
Old Oct 8, 2007 | 12:45 PM
mason's Avatar
mason
I'll see if I can find the part number tonight. It you find it first, Angelo, let the forum know. It'll probably come in handy for someone else.
Mason
