stuck glow plug....Help!
Old Oct 6, 2007 | 10:18 PM
zakquick's Avatar
zakquick
Hey all. Tore into replacing my GP's today, all went well until I had one come apart. The probe is stuck while the threaded sleeve and top cap came out. Dug through the archives and found some pretty good stuff, just thought I'd rack your brains for a fresh look. Baz says you can turn it over and hope it shoots out, sounds like a broken window at my neighbors house to me. Has anyone done this? thought maybe i could put it back together and just run it on 7 new GP's, but it seems like now that the plug has come apart, I could risk pieces everywhere. Thanks you guys, I have learned so much from this site just reading posts, I rarely need to post myself. FTE rules!
Old Oct 7, 2007 | 06:24 AM
Action4478's Avatar
Action4478
I have read that some have removed the injector , & using a shop vac & putting compressed air into the GP hole.....If it is still in there , you want to make sure you get it out,......
Old Oct 7, 2007 | 07:49 AM
beansdiesel's Avatar
beansdiesel
Take a pair of needle nose wise grips and make a slide hammer with it. You will need to pull out the threaded part that adjusts the vise grips and get a piece of all thread the same size. Then cut it to the length you need (if there is something in the way it will have to be shorter), get a nice heavy deepwell socket and put it on the shaft and put a nut and washer at the top. Now you can grip the top of the gp and hammer it out.
Old Oct 7, 2007 | 07:58 AM
wmiller's Avatar
wmiller
same thing happened to me last year when i did mine. You can use vice grips and try to work it out or you can try using the engines compression to push it out. IF you do this make sure you wrap something arouond it so it doesnt fall in teh cylinder. Mine wouldnt bust loss (mushroomed) and had to have the head pulled.
Old Oct 7, 2007 | 08:35 AM
ltfox's Avatar
ltfox
Spray it with alot of PB Blaster, let it sit for hours or even a day, and do what Bean suggested. Using the engines compression to push it out would be last resort for me.
Old Oct 7, 2007 | 10:07 AM
zakquick's Avatar
zakquick
Thanks boys. I like the slide hammer idea, headed out to get the parts now. What do you think about leaving it in for awhile, this is my work/everyday driver, if I can't get it out, that is.
Old Oct 7, 2007 | 10:57 AM
Cuda_jim's Avatar
Cuda_jim
As long as you're sure it won't drop into the cylinder.
Old Oct 13, 2007 | 04:09 PM
zakquick's Avatar
zakquick
Hey all, update on my situation.... I put her back together with the old stuck GP still stuck. Opened her up again this morning and the probe came right out with the sleeve, no problem. Threaded the last new GP in there, and closed it up. I started it up and I now have a chugging I never had. Very under powered. I did remove the rocker arm to give me some room to wrench. already checked everything else, its all there, no missing parts. What did I do?
Old Oct 13, 2007 | 05:54 PM
ltfox's Avatar
ltfox
Sounds like you may have left a connector undone. Ya might have to go back in and double check the electrical.
Old Oct 14, 2007 | 10:34 AM
zakquick's Avatar
zakquick
yeah..... roger that. apparently i need to be more careful when i slide the VC back on, i unclipped one of the yellow injector plugs. glad it was my fault and not a real problem. thanks guys!
Awitte58
Jul 13, 2012 09:26 PM
IDMooseMan
Nov 18, 2008 09:52 PM
61 uni
Dec 14, 2007 10:00 PM
Flea
Nov 28, 2007 03:11 PM
Powerstroke2000
Nov 23, 2005 12:49 AM
