hey guys, me again. heater core is replaced but now i got some leakage into the cab. could it be a bad hose?? following the core inlet and dripping down???
i did clean the cab side, made sure of that, so i guess i'll start checking hoses, if nothing's amiss, then its off to the parts store... thanks again guys!!!!
Scary. I replaced my heater core a couple of years ago, and dont plan to have to do it again for a long time. There are cheap cores out there. If you are buying another core, you might shop for a different brand. Cheap is not always better.
I found out the hard way...You need to be very gentle with heater cores. It's not to hard to brek the solder joint where the heater hose tubes connect to the core on the brass ones. Just wiggling a hose trying to free it from the heater core did it for me.
I was getting ready to warn about the same thing. Always cut old heater hoses off heater cores, never twist to break them loose. And be gentle putting the new ones on, and don't get carried away with hose clamp pressure. You can actually crush the pipe. I have learned all this the hard way.
