How Do You Know?
Old Oct 5, 2007 | 11:14 AM
i1dery's Avatar
i1dery
How Do You Know?
I have an 89 f250 460 and wanna know how to tell if it has a heated oxygen
sensor or not. As it is the O2 sensor appears to be mounted to a solid block
of metal welded between the exhaust tubes just before it enters the catilytic
converter.
And also would like to know whats steps to take for pulling codes on the same truck?
Old Oct 5, 2007 | 11:23 AM
Skandocious's Avatar
Skandocious
I don't believe that those oxygen sensors are heated, not sure on that.
As for pulling codes, here:
http://www.fordfuelinjection.com/?p=13
Old Oct 5, 2007 | 11:51 AM
i1dery's Avatar
i1dery
Thanks on the codes pulling info.
Old Oct 5, 2007 | 12:57 PM
Conanski's Avatar
Conanski
If you go back to the main page http://www.fordfuelinjection.com/ you'll see more info about all the different sensors. If you sensor has 3 or 4 wires it's heated.
Old Oct 5, 2007 | 01:06 PM
cleeE150's Avatar
cleeE150
I have 89 o2 sens same location ,non heated, I beleive it 2 wire.
Old Oct 5, 2007 | 02:04 PM
i1dery's Avatar
i1dery
The reason for this all is I have this wierd thing going on and Im trying to trouble shoot the problem. In another post it was mentioned that I may have a bad MAP sensor, but that part seems to simple to go bad, so im trying to figure out just what exactly causes my truck to ping, empty going up a hill at 6-8% grade, and run great loaded going up and over 6% grade, 3500ft pass???
