Found Carb Leak
Old Oct 4, 2007 | 10:34 PM
nbfnwe's Avatar
nbfnwe
Question Found Carb Leak
I Thought My Carb Hollly 650 Orig Ford F250 460 7.5l Was Leaking From The Mexican Rebuild But As I Looked Closer I Saw The Fuel Coming From The Back Of The Carb. I Said B4 The Front And Center Are Fine.. The Back Of The Carb Back Ports On The Drivers Side Has A Small Circle Near The Tube That Runs From The Front To The Back.. The Gas Is Coming From A Small Crack I Cant Even See It Is That Small But It Has A Crack..can This Be Fixed Or Do I Need New Carb.
