clutch
Old Oct 4, 2007 | 07:37 PM
macj's Avatar
macj
clutch
What is the average price for the replacement of a clutch on a 94 ford ranger?
Old Oct 4, 2007 | 08:20 PM
smithc185's Avatar
smithc185
From my experience for 2wd its about 400-500 4wd can be upwards of 700+
Old Oct 4, 2007 | 09:17 PM
Peter94's Avatar
Peter94
That is to have a shop do it right...?
Old Oct 5, 2007 | 04:48 AM
Pablo-UA's Avatar
Pablo-UA
what want U to change in your clutch? disk, pressure plate ore slave cyl. with bearing? You can easily do all in your rarage for weekend. much cheapper!
Old Oct 5, 2007 | 01:05 PM
customstringer's Avatar
customstringer
May depend on what part of the country you are in. With M5OD since you need to drop the tranny and should do both the slave cylinder and shift rail plugs while its out, even with 2WD you may get closer to 700-800 bucks. I debate on whether to do the master cylinder at the same time as well. If you are going to try to keep the truck another 100,000 miles, worth considering.
