Sponsored by: Kumho
which rims?
Old Oct 4, 2007 | 02:03 PM
joe69's Avatar
joe69
which rims?
I was want to get a set of 16x10 rims for my 99 f-150 4x4. I was wondering what bolt patter I needed to get.
here are the rims..
http://www.performancewheel.com/Deta...ry=2&gacid=902
Old Oct 5, 2007 | 07:55 AM
77300i6's Avatar
77300i6
Just tell whomever you speak with that you have a '99 F150. They should be able to look that up.
The bolt pattern is 5 x 135mm, but be sure to get the correct backspacing. If you're running wider wheels and tires than stock, you probably need less backspacing to keep the wheels/tires from hitting the suspension/brakes.
