Sponsored by: Real Truck
Rear End Fluid Question
Old Oct 4, 2007 | 12:03 PM
Bowstring's Avatar
Bowstring
10000 miles ago I had a rear pinion seal replaced , at that time the ford dealer replaced the fluid with 75/140 which they said ford had a new memo out to use instead of 80/90 for my Dana 80 rearend. My question is can that cause seals to start leaking. My pinion seals shows signs of wettness again and one of my rear axle seals has started to leak slighty. I have checked the vent tube and it seem ok.
Old Dec 19, 2007 | 08:03 PM
oltrucker's Avatar
oltrucker
the dealer is right. it has to be synthetic gear lube. no, it wil not cause it to leak,,sometimes a new pinion seal will weep a little until it seats in. dont worry about it unless it actually drips lube.
