360 timing gear situation
Old Dec 5, 2001 | 09:29 AM
fasch74's Avatar
fasch74
Rebuilding a 360 we ran into the problem of the pin that goes into the fuel pump eccentric is too short. We thought this was just the wrong timing gear set...but we returned the other one and the new one is exactly the same situation. A local mechanic said just to fill the hole with tin foil. Im kind of skeptical about that. Any other suggestions? Thanks.
Old Dec 5, 2001 | 07:09 PM
Like M. Fords's Avatar
Like M. Fords
Go to the hardware store and get a longer dowel pin. They should be case-hardened, so if you get one too long, you will have to cut it with an abrassive wheel or trim it with a grinder.
Old Dec 6, 2001 | 10:15 AM
Sunny_in_hollister's Avatar
Sunny_in_hollister
I've got a few spare ones - I had to order a whole box to get a replacement. How long is the one you are using?
Reggie
Old Dec 7, 2001 | 04:51 PM
jowilker's Avatar
jowilker
ecidemon
May 13, 2011 11:55 PM
73F100*8Mile
Oct 10, 2007 01:04 AM
Paco
Feb 28, 2005 11:20 AM
eric in tn
17
Apr 11, 2003 01:46 AM
Rat wagon
20
Mar 2, 2003 11:26 AM
