Sponsored by: Real Truck
Turn Signal Issues
Old Oct 4, 2007 | 08:21 AM
dscofever's Avatar
dscofever
Turn Signal Issues
OK, my right side turn signal is acting up and I want to see if anyone else is having any issues like this. Or if someone knows what is wrong.
2005 F-250 CC and when I turn on my right turn signal the sound (clicking) is very fast and the signal on my dash is not on. If I wait anywhere from 5-30 seconds, the lights finally work correctly. I figure burned out bulb...back is working, but front and side view mirror is not working. I buy a bulb for the front, Pep Boys couldn't find a bulb for the mirror. I replace, and it's still happening.
What could it be? I have no idea.
BTW, it's worse when it's cold.
Old Oct 4, 2007 | 08:49 AM
rbaker6336's Avatar
rbaker6336
sounds like a bulb
Old Oct 4, 2007 | 10:40 AM
Beerstalker's Avatar
Beerstalker
When you replaced the front bulb did it start working or not?
The mirror lights are LED's and you have to replace the whole light assembly.
It sounds to me like you have a wiring problem.
Old Oct 4, 2007 | 02:20 PM
Layson's Avatar
Layson
yeah sounds like a short or something... if the LED's are not working. maybe one of the wires near the front bulb are rubbing against something and shorting them out???? that is tough to figure out..
good luck,
Steven
Old Oct 4, 2007 | 07:07 PM
dscofever's Avatar
dscofever
On the way home today, everytime it acted like it wouldn't work, I would hit the steering wheel and EVERYTIME it fixed it until the blinker went off. Turn it back on, and hit the steering wheel = works. I think it might be a loose connection under my dash. If it were a short, it would most likely pop the fuse.
Old Oct 4, 2007 | 07:18 PM
IHbase's Avatar
IHbase
Similar issues with 00 truck. Blinker switch cured issue.
-Mike
Old Oct 4, 2007 | 09:28 PM
merlins'92f250d's Avatar
merlins'92f250d
Had the same problem with my 2000 also (except no mirror lites) ended up changing the turn signal switch twice (first one worked but only lasted a few months) after that the second one lasted over a year then I sold the truck
Old Oct 4, 2007 | 10:58 PM
dscofever's Avatar
dscofever
I have two questions for you, how much was the switch and how hard was it to install? Or did you pay to have it installed?
OK...I guess that's 3 questions.
Old Oct 5, 2007 | 09:16 AM
merlins'92f250d
I dont have my receipts for the switch with me right now, but if I remember it was something like $125 installed at local dealer
Old Oct 5, 2007 | 10:11 AM
05lariatPSD's Avatar
05lariatPSD
It's definitely the turn signal stalk. Mine has been doing it for 2-3 months on the right side. On mine, if I use the signal in the passing mode it operates normally so it hasn't been a high priority.
The stalk is pretty easy to replace...remove a couple of screws under your steering column and look for the screws holding the stalk in place remove the connector and replace the stalk.
Old Nov 14, 2007 | 05:22 PM
bkvanbek's Avatar
bkvanbek
Did you get this worked out?
I have a similar problem. Nothing happens when I use the turn signal switch, other than some faint buzzing like an electrical short. The hazard lights work except; only the left turn indicator on the dash flashes and the right front and mirror do not flash. All the fuses ar okay.
Old Nov 16, 2007 | 10:52 PM
dscofever's Avatar
dscofever
I have not fixed it yet. If I just hold the stalk against the bump, than it works. I want to see if I can buy the parts and do it myself. Been a little busy with work to do that.
Old Nov 17, 2007 | 06:12 AM
bkvanbek's Avatar
bkvanbek
I just bought a replacement multifunction switch ($91.16) and it fixed the problem. I had taken the switch apart, but it is not serviceable, parts flew in all directions. It was easy to replace.
I looked on the Internet and there was a few that were cheaper, but I do not think they were "Ford". My original switch was made in Poland and the replacement Mexico. I would try one of the cheap ones, it could not be made any worse than the Ford one. The parts guy said they sell a lot.
Old Jan 31, 2008 | 11:25 AM
cbsquidss's Avatar
cbsquidss
Arrow Similar but ODD Turn Signal problems
I have just recently had similar issues. Yesterday, for the first time, my 2000 F250 Diesel turn signals started acting up – here are the observed symptoms:
With either parking or headlights ON, the left works fine but the right side does not work (no switching or external blinking, but the internal right arrow stays ON permanently)
With the lights off, both left and right work, but when the right turn signal blinks, on the OFF cycle the dash (gages, radio, ect) all light up. Basically the right turn signal works, but the dash looks like a Christmas tree.
With the hazards on, with the lights ON, neither the right nor left flash, but with the lights OFF, all lights flash and the interior lights flash as well.
All bulbs are good. Hmm, what else… I have nurf bars with LEDs installed, which I wired up to the truck per the instructions, which normally are ON with the lights, and blink with the turn signals. Bothe right and left are not lite now. I might disconnect these to see if there is a connection, but they worked perfectly up till very recently.
Old Feb 19, 2008 | 04:08 PM
fireworm's Avatar
fireworm
I have this exact same problem with my 2003 F-250. I replaced the flasher but the problem still remains could it be something that can be fixed out of the shop or do I need to take it to the Ford house?
