Tranny info
Old Dec 13, 2001 | 12:03 PM
rodeofordman's Avatar
rodeofordman
Tranny info
I was wondering if you could take a 5 speed tranny out of a newer (late 80's early 90's) ford, and change the bellhousing off a 4 speed and bolt it on the 5 speed "engine 390 4 wheel drive" and make it work.
Old Dec 13, 2001 | 08:21 PM
ecarter50's Avatar
ecarter50
Tranny info
the bellhousing is part of the trans case on the 5 speeds both the ZF and M50. they can be bolted to either 351m/400/460 or 300/302/351w
Old Dec 14, 2001 | 12:28 AM
FE427TP's Avatar
FE427TP
Tranny info
If you have a divorced transfer case there is a strong possibility that you can, you will need a 5 speed tremec TKO transmission (around $1400) and a spacer to move it back about 3/4" and possibly new driveshafts if you have to move the transfer case. you'd probably be better off running taller tires or higher gears.
Old Dec 14, 2001 | 01:52 PM
ButchWhitehouse's Avatar
ButchWhitehouse
Tranny info
